- Joined
- 5 Dec 2012
- Messages
- 929
- Reaction score
- 13
- Country
I've ripped out my floor to level the joists and at the same time i am moving a radiator in bedroom and installing new bathroom - stud wall exposed in bathroom and joists exposed in both rooms at the moment.
I plan on installing the chipboard floor this weekend. In the bathroom i will sort out the hot\cold supply by running it through the stud wall to the shower\sink\toilet area. but wanted to ask:
For the toilet supply and radiator pipes coming out of the floor, do you connect the vertical pipe coming from the elbow under floor into the bottom of radiator first, and then drill a hole in the chipboard, then slot it over the pipe, and then tighten it up on the rad / toilet cistern valve?
cheers
cheers
