Hi all,
I'm renovating a bungalow and have agreed with my plumber that I will install the radiators and pipework for the central heating system so that he can them install a new boiler.
I understand the basic logic of the pipework in that each radiator needs a feed from the boiler and a return to it but I'm puzzling on how to organise the return pipe so that the water successfully returns to the boiler.
Simple, I thought at first, start with the radiator furthest from the boiler and run past each of the other radiators branching in with a T-connection in each case.
My problem is, the boiler is situated in the middle of seven radiators and I will have to run from two different ends picking up the others as I pass by. What happens when I then have two return pipes coming from different directions meeting up under the boiler?
I guess join them together with a T-connection and then go back to the boiler. However, if I take two return flows into a T-connection that are facing eachother (and maybe one has more pressure than the other) can I be certain they will both turn the corner and go up to the boiler?
Or should I arrange it in a different way?
I hope I've explained myself clearly....let me know if I haven't!
Jever
Jever
