Hi I’m new to this forum so any help is most welcome. I’m installing a completely new heating plumbing system in a domestic referb, and could do with a tip or two on running my pipework to multiple (3-4) showers to minimise pressure fluctuations. I’m beginning to think my design is a bit OTT. Can someone please advise if I’m on the right lines, or can I simplify the circuits & installation cost. I need it to be right as I’m only doing it once, cost is less important, having just spent £2K on a HeatBank.
I have just over 35lt/min at 7 bar incoming, via 25mm pipe directly to a DPS heatbank from the stop-cock. Just before the tank I recon to spur off for cold to sinks etc etc , and put a pressure reducer set to say 3-4 bar for this part of the circuit. Another reducer set to 6 bar (max capacity for the heatX) goes both into the HW side of the plate heatX and a 2nd cold spur to feed only the showers. One question is; do I need yet another pressure reducer on the spur, after the heatX to supply hot to only the sinks, leaving the shower hot supply pipework dedicated at 6 bar, (less the pressure drop across the heatX)? This means I have dedicated H&C to sinks at 3-4 bar and 6 ish bar to the showers. The next consideration I have is the dedicated piping to the showers. Should they be run independently from the origin (ie parallel circuits,)or can I run 15mm pipe in series without one shower upsetting another? I don’t want to use 22mm if possible as it will take a long time for the hot to get through each time the shower is used. There are three showers with normal cheap mixer valves & small shower heads, (with a 4th planned next year). The mixers are probably only 5-8 lirs/min each not much more. (I don’t believe in using masses of water in a “power” shower as they consume too much energy). I have a new 26/36KW boiler serving the heat bank & solar of course. The plate heatX is rated to 45lt/min, more than I have available.
All in all I seem have a lot of separate pipes running from the heat bank. Perhaps there is a better way? On the other hand this might be the setup needed when a car full of wet, cold Cornish surfers arrive and all need a hot shower quick!
Many thanks in anticipation.
