hi guys...i want to put a new electric shower into my bathroom..it will be fixed over the bath...BUT there are no water pipes close to where i want to put shower....so here is the question...can i /should i be able to run a cold water pipe from the loft ( channelling it into the wall) down to where i wish to have shower fitted ?. in the loft is the main water tank,header tank etc with all the appropiate pipework fitted to run the hot water,cold water etc thru the house..so, if i could add & run a cold water pipe from the pipes in the loft to connect to an elecric shower...which water pipe would i need to connect to in the loft ?..i hope this makes some sense..much obliged for any advice or help/suggestions...cheers
ps.. i have an electrician mate to make the electrical connections..cheers again
