Hi I haven't been on here for a while. I hope everyone is doing well.
I about but am about to pull out an old bathroom in a flat that needs renovating.
The water is fed from a tank next to the bathroom but being a flat is only at say 1.5m above floor level. The water pressure is p!55 poor.
The bathroom has a power shower which is ok. I plan to retain this but was thinking to better the bath and basin to install a pump (Salamandrin type) as long as I can get power to it.
If I do this do I just tap into the 20mm pipes currently serving the bath, reduce just before the pump and then come out the pump in 15mm and T to the bath and basin taps? I know bath taps are normally 20mm all the way through but does this become 15mm if via a pump?
Also I assume the WC stays on the mains.
Any help much appreciated.
