Piping through joists
8 Feb 2007
Hi, I have to move a radiator which involves lifting one floorboard the length of the room and passing two 15mm pipes across/through about 20 joists!
Is this a problem? Am I OK to cut a 15mm deep slot in the top of each joist and rest the pipes in the slot?
I will lag the pipes slightly to prevent creaking, my main concern is the load bearing capacity of joists with a slot in them!!
I'd welcome any ideas on this. Thanks a lot - Chris
Cut a 20 mm deep notch in the joists. You are allowed to notch up to 1/8 of joist depth (assuming yours are 8x2 joists) :D
Do lag to avoid expansion noises. :!:
Don't forget that notches are only permitted in certain parts of a joist - Between 0.07 and 0.25 span, IIRC
Similarly, holes through joists are permitted on the centre line in the area 0.25 - 0.4 span, and should be no closer than three diameters apart.
