Piping up bath
16 Jul 2009
Hull
Do most plumbers use flexis now when installing a new bath?
1. Rather depends what the taps come with.
2. Flexis are restrictive of flow.
3. If you have a hot water cylinder (vented or unvented) try and go with 22 mm hard piped, preferably copper, where hot and cold have 3/4" BSP inlets.
4. If you have a combi, 15 mm hard piped is better in that you lose less cooled off hot water in the pipes. But a combi is likely to give you a slow filling bath anyway, limited by its capacity to heat water instantaneously.
Most the time would use 22mm pipe with tap connectors and fibre or rubber washers.
If it's a smaller combi though then a thought would be to use flexi's to reduce the flow through the pipe to help keep the HW temp up. Never tested that though most bath taps on a combi have to be wound back a bit to keep the flow temp hot enough.
