My mother has a 400w PIR floodlight on the outside rear of her bungalow. The cable is fed through a door frame (which is below the light) and it's plugged into a ring main socket in the room.
In the adjacent room there is an overhead single tube fluorescent light fitting, run off the lighting circuit.
Both lights have been in place for many years without any problems.
She recently noticed that when she turns on the fluorescent light, the outside PIR light also comes on. This only happens in the evening when it's dark outside.
I thought the fluorescent light was bit noisy when turned on so I replaced the starter. This made it a lot quieter but the problem still exists.
Can anyone please explain why the outside PIR light is coming on when the inside fluorescent light is turned on, and suggest a way to stop it happening?
Many thanks,
Ray
Many thanks,
Ray
