- Joined
- 10 Nov 2014
- Messages
- 41
- Reaction score
- 2
- Country
Hi all,
I'm after some advice about my external lights. I know nothing about electrics so wondered if someone could throw me some pointers about what could be going on.
Have several coach style PIR lanterns on the outside of the house (the ASD ones sold by Screwfix). Getting some odd behaviour from them - each time there's a different light that seems to be playing up. I had some replaced thinking the units were faulty and all has been fine for a couple of months. Now they've started playing up again.
Have had two electricians check the wiring to the outside and both have said all is okay.
Setup is:
3 lanterns at front of house on their own switch (no issues with these)
1 lantern on one side of the house on its own switch (no issues with this one)
3 lanterns at the back of the property and 1 more to the other side of the house - all on the same switch (these are all the 4 that have been giving me grief).
Lights are supposed to work on the PIR but with the over ride on the switch to keep them on for an 8 hour period if you flick them on and off rapidly.
Faults have included;
- random light coming on when powered on but then staying on instead of exiting testing mode after 30 seconds
- random light not coming on when powered on. Then coming on for no apparent reason some time later and refusing to go off until the power is cut at the switch.
- light coming on and then going straight off and refusing to trigger again (so does not even stay in testing mode for 30 seconds).
When I say random, it's random in so far as one will suddenly start playing up and then continue to exhibit that behaviour until the unit is replaced.
No visible signs of water ingress to them and all siliconed up properly as per the instructions for extra protection.
I noticed today in the instructions it says
" 100w maximum bulbs to be fitted" (which I think is what the electrician used - can't check as the print is faded but they're the large old style ones). Then straight after it says "250w maximum total".
Is it as simple as 4x100w on one switch being too far over what it should be and causing damage to the sensors? Or am I overly simplifying this?
Setup is:
