hello again,
I think there may be a fault with one of my PIRs. it has always worked.. until now.
This pir was set as Entry / exit 2 in (attributes 1), and Zone type Guard.
therfore in Part arm if triggered would set the entry exit tones.. and has worked as it should for a while now..
this morning i have tested the pir with full arm and part arm and there is no trigger at all.. the LED lights up but will not trigger the alarm.. all other Pir work as they should. Walk test shows Pir working as it should
The panel is a elite 48.. the Pir is an AFF-0001 Grade 2 . wired to keypad 1 zone 2 mapped to zone 10, the panel has Dc filter and Ac filter Ac accross DC and earth is 0.8 v.
has anyone come accross this before.. any other tests to make.. my gut feeling says order a new PIR..
