Hi all,
I'm in the process of planning an upgrade to my loft insulation. I already have rockwool inbetween the joists in the ceiling/loft floor and I'm planning on adding another 250mm at 90 degrees, following guidence, and avoiding the loft ventilation areas.
However I use this attic space to store some items that can be prone to damage from external tempatures. Vinyl records etc.
Because of this i'm looking to insulate between the rafters with PIR (and gapotape) leaving a 25mm gap between the insulation and the felt under the roof tiles for ventilation. This in theory, from my research will be acceptable, were it not for the fact that I'm not introducing an alternative ventilation while blocking the existing ventilation in the loft space with this new layer of insulation.
My question is, what's the best option to ventilate this new "room" I'm creating?
As as far is it goes for now, the loft is basically like being outside, great ventilation and temperatures matching the other side of the tiles.
