PIR Lights
5 May 2010
HI guys i wired 2 PIR lights in parellel and took the supply from a 10Amp MCB from the consumer unit, from thios MCB another 2 PIR lights are also connected. My problem is these lights are staying on and wont go off, they are very cheap lights and i am going to replace them , my question is. is my wiring effecting their performance. The twin and earht cable is coming from the fuseboard to the first light and looped onto the second light, is it ok to feed the light with a flex instead of the twin and earth.
Thanks guys
I understand having two PIR lights on the same circuit can sometimes cause problems like this (although it shouldn't). You could always try replacing them with more reputable fittings.
The description you give for the wiring sounds ok.
I presume its just the fittings and im going to firstly replace them after that ill check my wiring. I ve wired the supply into a junction box and feed the lights via a flew for comestics, i dont think this should effect it though, im going to change the lights anyway, what would be a reasonable amount of money to pay for a decent fitting.
I changed those fittings to slightly more expensive fittings. worked fine wired in parrellel, the previous fittings had been there two years and were extremely cheap fittings.
cheers
