PIR outside light, but with 90 degree mounting?
1 Mar 2008
I'm planning to add an outside light with a PIR to the corner of a garden shed, and was looking to find something similar to this, but that can be fixed on a 90 degree corner of the building.
https://www.screwfix.com/p/asd-black-bc-pir-master-half-lantern-wall-light-with-pir-60w/45075
Screwfix part number 45075 if the forum messes up the link :D
Has anyone seen anything along these lines that they could suggest? A quick search through only finds bracket type lights that stick out a long way from the corner, which isn't really what I want.
The alternative is obviously a stand-alone PIR to use with a normal light, but and all-in-one fitting will be more straightforward, so would be preferable really.
Any suggestions much appreciated.
Thanks,
Colin
Perhaps get a couple of pieces of Arris rail (or make your own) either side of the corner to give you a flat face to fix to?
