Can anything be done with a PIR security light that is permantly ON, turned the mains off to do a small job elsewhere, but after turning the supply back on, this security light stays on all the time,
Did you flick the mains off and then back on quickly - this can trigger a few of these to remain on as an overide. Try turning off the power to the PIR again then wait a few seconds before turning back on. The light may take a while to initialise so may stay on for a bit and then go off.
