Hi all,
I want to fit an outside light which comes on when you walk up the drive. The actual light that I want does not have PIR built in, but I believe you can buy a separate PIR sensor and fit it to the light.
Is this correct?
Is it hard to do?
I already have the wiring in place for the light, and it is operated by a switch. Presumably this doesn't affect whether or not I can fix a PIR sensor?
Thanks!
Matt
Is this correct?
Is it hard to do?
Thanks!
Matt
