I am planning on insulating a basement.
Would XPS be a suitable product for this as it has a low moisture absorption and tolerance of wet environments (v PIR).
Basement walls are uneven so would rigid board be a hassle to fix? Planning to use adhesive to stick the boards as I do not want to compromise the tanking on the walls.
Once i get the boards on I will be installing a metal stud in front (so will help keep the rigid boards pressed back) with 50mm of rockwool or glasswool insulation in between the studs.
