I inherited a 15-year-old Galaxy 8 alarm system in my house, which has finally died.
I just want a simple system, so I’m considering a DIY replacement with an Accenta Mini G4 panel/RKP (click here) with a Reson8 bellbox (click here).
All 5 of the PIRs are already fairly new replacements (click here) of the decrepit originals. They are all wired using only 4 cores and a couple of resistors between some of the terminals, which I think is instead of a normal tamper circuit.
So, two questions:
1. Will the Accenta panel work with PIRs wired in this way?
2. If I need to, would it work with some PIRs wired this way, and some conventionally? Most of the cabling is 8-core, but some previously extended bits look to be only 4-core.
Cheers
So, two questions:
Cheers
