with winter coming im thinking of adding some PIR's to the existing lighting within certain rooms, which should save electricity and keep rooms to a safe lighting level.
if possible i would like to keep the existing option of being able to switch the lights on or off, regardless of the fact some of the PIR's ive been looking at can have their settings changed. ie watching a movie on tv in the dark - cant turn light off!
i have seen some replacement switches that have pir's built in and it states that they are only suitable for "ordinary incandescent and tungsten lighting, and is not suitable for use with energy saving, low voltage, halogen or fluorescent lighting".
can be seen on http://www.maplin.co.uk/Search.aspx?criteria=pir switch&source=15&SD=Y
now my question is can it be done whilst keeping existing switches, can these PIR's be used http://www.maplin.co.uk/module.aspx?ITAG=SPEC&ModuleNo=3141&doy=25m9#spec is there any reason why engery saving bulbs etc cant be used?
my next plan is to have stair lighting, possibly built into the side of the steps so that if the stairs PIR is active then it lights some small bulbs (halogens???)/LED arrays. these would work independant of the normal house lighting and would be primarily for getting home late and not being forced to put normal lights on which would annoy/wake up other people, but allow people to safely see the stairs and any objects that may even be on them. i was thinking of using the same type PIR as planned for the other project above, but then simply connect the pir and lighting to a normal 13 plug ?
