Dear All,
Wondering if you could all provide some assistance and advice on a new roof that I'm having built please which is across an existing part of a kitchen and a new part which will be a new extension.
When the extension is built, the roof height will have to be reduced to clear some bedroom windows. As a result, there will be flat section followed by the pitched roof to clear the bedroom windows.
This is what the roof looks like that the moment :
And this is what it will look like when the new extension is built:
As mentioned, there will be a flat section to clear the bedroom windows:
My builder has raised a couple of questions, which may have been overlooked initially, because there is a question mark over how the flat section will be supported because from within the kitchen the ceiling section will be open and not a flat ceiling
At the moment, the only solution is to change the roof pitch to eliminate the flat section however I was wondering if there are any other options?
Speaking with another carpenter, they suggested the following type of design which means taking away some of the openness of the ceiling from the inside but it may be our only solution.
Any suggestions would be welcomed. Thank you
