must be resin build up try meths
do not under any circumstances be tempted to knock it off by planing a bit off wood as the other blade will catch it and shards will go everywhere at 30.000rpm
yes sorry more drip or pat with a well soaked cloth or several layers off kitchen roll
and with gregers great advice use wood or about 10 layers off paper to protect the blades
Yes Got The blade out. Bought some Meth from b&q, Used The Cap To pour a little down the blade sides, Then gave it a couple light taps and it slid out no problem. loosened only Two hexi screws.
