Hello
so, basically I need a power lead extension that shall power my small work area.
I am not 100% sure on the length of wire needed yet, but plan to have it wheeled outside of the property to cut large sheet goods down.
so, here is everything I think I need, if you think I need more or something different please let me know.
I need a 3 core wire about 15meters… no idea on thickness recommendations
A weather resistant plug system that has emergency off pedal and enough plugs for at least 3 items such as mitre saw, table saw and battery charging, with option to unplug and use other power tools, such as an arc welder, router grinder and more.
a wind up cable as no permanent power will be installed.
some light system to show power is on
i am confident on everything I need, but want to be sure that I am 100% correct here.
1mm 3 core round flex 15+meters
Off-On Red Cover Emergency Stop Push Button Switch 16A Power-OFF
outdoor plug socket - 3 plug if they do them
240v Mains Amber Neon Indicator
unless you can get a windup reel, empty case I will probably use the weather resistant boxes and wind up the cable by hand.
is there anything else I have forgotten, need up change before I order everything?
I will get my mum to wire everything up, she was a school site manager, caretaker site Forman and has been to college to get the license to do electrical work as many other jobs needed to run a school, oversee 2 brand new buildings plus a whole new school. So all safe there.
