We want to convert the loft on our Victorian end terrace house to add a master bedroom and ensuite. For some reason best known to the Victorians our original roof design is different from all other houses in the street and immediate neighbourhood. In addition to having a hip roof it also has an unusually low pitch, which means that the existing volume under the roof is really tiny for a house of this style and footprint. Based on a precedent in our neighbourhood we successfully applied for householder planning permission to raise the ridge. However, our architectural designer has not been able to come up with a satisfactory design for the extension that complies with the volume restrictions under PD. Whereas many neighbouring properties have been able to extend over both the main roof space and the rear outrigger, gaining sufficient space for two bedrooms or one bedroom and an ensuite, our low existing volume means we only have enough volume for a dormer over the main bit of the house, which would be insufficient for a bedroom plus ensuite. It's been suggested to us that there is no point applying for householder planning permission for a larger extension, as the volume increase under PD is the maximum we would ever get. Is this right? Ideally we would like to build an extension which would look indistinguishable from what many of our neighbours already have, it's just that because our existing roof volume is so low we would need to add more volume than the neighbours to achieve the same end result. Is there any point making this argument or would we simply be flogging a dead horse?
