Morning all
I intend to build a large shed/workshop in my driveway, and just want to confirm about planning permission/building regs. The floor area will be 14.5m, so I believe it falls under permitted development. It will be against the boundary.
My 1st thought was a lean-to build, using the side of the house as one side, however I believe it needs to comply with building regs if I do this. Not sure what parts of the regs it has to comply with, but im guessing it will end up costing more than simply doing a detached shed.
If I do a detached shed, then I believe building regs do not apply, as long as its less than 15 sq metres. A question, is it still detached if it is put hard up against the side of the house? If not, what is classed as detached? A 1 inch gap between shed and house?
Anyway, just wanted to know if Im in the right ballpark with the planning permission and building regs.
Thanks guys.
Thanks guys.
