Our house is all timber construction, larch cladded. We'd like to extend it to one side to form a decent sized living room, maybe 6mx5m. It would literally be like adding an insulated large pent shed on to the house, and the existing overhanging eaves of the roof above mean it would be simple to make watertight during construction.
Should I get an architectural tech or architect to draw up the plans or should I get the walls and floor sections(the house is on stilts) done by the contractor who built the originals, would they draw up the plans as part of a package? I plan to do most of the work myself(I'm a stonemason with HNC building so this is fairly easy), but then I think...hmmmm...could I do the plans myself? Biggest pitfall I can see relates to various regs and environmental requirements on U-values/insulation. Walls on the house are 300mm thick insulated so would keep this the same regardless....I'll be doing all the founds myself, whether that entails pads like the existing build or strip founds.
Just trying to keep things cheap but want this put up quick. I'll also be doing all the sheet metal roofing to match the existing.
Any advice appreciated!
