Hi All
Just been looking at the plans of the most recent extension on my house that was done by the previous owner. They submitted a plan in 2010 to add a second storey which included knocking down a 3m x 4m front single-storey extension effectively reducing the floor space downstairs. This plan failed, I think because they did not agree to a bat survey in time (not sure on this exact point). They submitted new plans with the required bat surveys 6 months later but on these plans the downstairs extension was removed from the side profiles but still present on the proposed floor plan. The planning officer still made reference to the earlier planning application and also to the single storey extension being knocked down which made the second storey more acceptable.
Planning was approved in 2011 and think the building was completed in 2012.
It all looks a bit dodgy to me!
The questions are -
1) Assuming the front extension should have been removed does the 4 year rule apply? As I understand it, if the building goes unnoticed for 4 years then it stays.
2) If the 4 year rule applies is this from date of issue of the building regs completion certificate?
I plan to make some changes under increased PD rules but don't want to have planning sniffing around if there is a potential issue.
Thanks.
The questions are -
Thanks.
