Plasson 25mm mdpe to 22mm copper fitting
Thanks can you use a pair of grips to undo it as I don't have one of those plastic wrenches it shows?
Yea, probably, as long as it gets a good hold.
Not ideal to re-use but I've re-used polyplumb fittings and grab rings and they are the same, just ensure the teeth are as level as possible and not bent.
Cut pipe after the grab ring and pull ring off from the back, with the teeth facing away from the direction of pulling. Pulling against the teeth will bend them making it pretty unusable.
