I've just started stripped out a house to redecorate. Walls are papered which has later been paint. The top, finish coat of the plaster is coming off. So far on the 2 half walls that have been stripped, about 90% has come off. Pull the paper seems to pull the plaster off most times. Streaming difficult bits often causes the plaster to blow. Finish plaster coat is quite thin 2-3mm, sometimes less. In one case the electric cable plastic conduit is level with the undercoat with only the finish plaster over it.
House was built in 1986 so cavity wall with cavity half filled. Later cavity wall filling was inserted (pilkinton superfil rock fibre).
Could this be damp? Or was it is just a rubbish job, bad plaster, undercoat too dry?
