I am fitting a new bathroom, taking the bath out and fitting shower instead. When I have removed the bath and old tiles from the wall a lot of plaster has came away to reveal brick work in some places and in others it's not as deep and has revealed old plaster or cement on top of the brick. In most places it's over an inch deep from the surface plaster.
What should I do to make it all even, should I use cement or plaster keeping in mind it will be a minimum of an inch thick and it will be PVC wall panels I'll be using to finish it.
If the best option is cement what ratio of cement, sand and water do I use.
Any help appreciated its all driving me bonkers
Cheers,
Col
Cheers,
Col
