Hello all.
Looking for some advice.
I am in the process of decorating a room in my house (circa 1900). This room has been neglected by what I can only assume has been the last 3 or 4 owners and so is in dire need of work.
I have stripped the woodchip wall paper to reveal some rather badly damaged plaster work.
At some point in the past there has been some movement in the building, which has badly cracked the plasterwork, running up through the cornice, ceiling and into the adjoining room.
The image below shows a section of said damaged plaster. It's not a great image and the stripper puts it out of proportion, that section is actually maybe forearm length.
I have pulled off all the blown bits so I'm now left with a rather big hole, which needs to be filled before we line with lining paper and then paper on top.
What should I fill this with? Plaster, PollyFiller?
Also, there are gaps in some places where each wall joins and the walls seem springy at those points (ie they move when you press them). I would have thought it'd be a good idea to deal with that before I paper over it.
Any advice appreciated.
