Hiya guys,
We recently moved into a new build property. The shower waste wasn't fitted properly and we had a small leak from this. It dripped through what I'm assuming was plasterboard right in the corner where the sloping ceiling above the stairs meets the flat ceiling of the front door area.
It probably leaked 50-100ml or something small. Was a small wet patch on the carpet and a tiny bit in a bucket after we noticed it. The plasterboard was wet in a strip of maybe 15cmx2cm.
Picture of when it was wet:
I can't see any signs of damage other than some paint missing from the metal join/corner point now its dry.
Should I be concerned/ demanding the builders replace that part of the plasterboard? Or as long as its dry and there's no visible damage will it be ok?
