plasterboard ceiling
10 Dec 2005
We had a bath run over a couple of months ago, we are now in the process of having our downstairs ceiling replaced by the insurers company.
The original ceiling was 1/2 inch plasterboard, the replacement looks like 3/8 but I assume that is not really a problem on the ceiling.
My main worry is that the plasterboard has been fitted and a first skim applied. Along the length and some parts on the width there is a prominent slightly proud line. Hopefully the decorator will not leave it like that. I thought the way to fit plasterboard was to buy it with a slight taper or scallop at the edge, so that when you joint it you have a slight recess to apply your tape onto, and then skim over this so there is a perfectly even join. I'm wondering if our ceiling has been done with square joints.
Does anyone know if this is ok or are we lilkely to be left with some lines at the joints?
is it a kitchen ceiling? if it was originaly half inch then it should of been replaced with half inch. you shouldnt see a line and its not the painters responsability. it doesnt matter if its being skimmed wether you use tapered boards but i always use them. if theyve used 3/8 there penny pinching and if there a fire your boards wont give you that extra few minutes and may cancell your insurance.
My thoughts exactly.....theres no reason why you should have a line especially as the ceiling has been skimmed.
Are you sure its a bump though and not a mark caused by uneven drying?
Did the builder come via the insurerer?...if so then they sometimes try and keep costs to a minimum...which is snidy
Ceilings down again, they are going to do it properly this time, thanks for the help and reassurance.
DD
