Hi All and thanks for taking the time to look at my post. I live in an old Cornish unit house and have just had the living room re plastered. The walls at either end of the room were concrete. The walls were plaster boarded and plastered and all is well. But I have hit a problem now I am trying to put up the curtain rails. I can't just have the rails supported on the new plasterboard can I ??
Have I got to drill into the concrete wall behind? if so what type of fixing do i use and also there is approx one and a half in void between the old concrete wall and the plasterboard so if i do drill into the original concrete wall the fixing I use will not be supported by anything in the void?? I hope this makes sense as i am stuck for a solution. Any help would be very much appreciated.
