Plasterboard in bathroom
19 Oct 2011
Merseyside
Hi.
I have had 2 walls in my bathroom and my ceiling reboarded and plastered with normal plaster board.
I've just had a tiler tell me that my walls need reboarding again with moisture resistant plaster board before tiling.
he didn't mention my ceiling, does that need doing aswell?
Aquapanel or hardibacker board in the shower enclosure would be best.
however Plasterboard will survive if you apply a complete coat of waterproof adhesive to the area to be tiled and a good quality waterproof grout.
Normal plasterboard on the ceiling is fine.
Wouldn't condensation have an effect on normal plasterboard on the ceiling?
What type of waterproof adhesive do you recommend? :)
Regular plasterboard is just fine in a bathroom. Tank any wet areas using a Mapei kit. http://www.screwfix.com/p/mapei-shower-waterproofing-kit/78484
MR plasterboard is just that, moisture resistant. Not waterproof. Same goes for cement boards. They are not waterproof, they just don't degrade when wet. What you want is a waterproof surface and tanking gives you just that.
Use a good quality cement based powdered adhesive and grout.
As for condensation install the correct sized humidistat controlled extractor for the room.
