STILL underway with the old loft conversion its coming along slowly.
I had the roof sprayed with foam, this maintains the U Value required and its thickness is the same as the rafters so I can maintain a good head height.
Im upto plaster boarding it all but im not sure if I should use foil backed boards or plain boards? Also which thickness should I go for?
Thanks in advance,
Con1_uk.
Thanks in advance,
Con1_uk.
