Hi all!
This is my first post....i'm a total DIY novice so take it easy.
Ok.....i am getting some work done to a wall. The current state of the wall: it is exposed down to the bare bricks. My plasterer plans to use adhesive to stick plasterboard onto the wall. He will then plaster over the top.
Is this the best approach???
Previously the wall was covered by some sort of cement mix which had then been plastered. This seemed to give a much more solid finish...should this be done again?
