I'm looking to use plasterboard adhesive to stick 18mm plaster over 25mm plastic surface trunking (https://www.superlecdirect.com/6219...erm=4580840336906636&utm_content=All Products) onto a ground floor solid brick wall. So the plasterboard will stick out more. I will use more adhesive to make sure that the plasterboard will stick properly. Hope this is ok? Do I need to add masonry screws (through plasterboard into brick) to reinforce?
This surface trunking is to allow me to add in 2.5mm2 electric cables for wall sockets in the future which I can do by (knowing where the surface trunking is) thread said cable into the trunking and up behind the plasterboard then up into the void space above the ceiling.
