Hi all
Does anyone have any advice on how to get a clean joint between plasterboard and wood, mostly plywood?
I have several joints where plywood walls meet plasterboard ceilings. My first choice would have been cover the ply with plasterboard and corner tape / fill as usual, but due to existing door and window frames the extra depth of plasterboard isn't an option.
I've primed all the surfaces and caulked the gaps - is it possible to tape and fill the joints as usual or will the filler flake from the ply?
Also, does anyone have any tips of how to get a clean joint between plasterboard and door frames / window in-goes as I'm trying to avoid using facings? I've had some success with a simple butt joint, caulk, skim of filler and paint but I've had to return to several of them to repair (probably inevitable) cracks. I think the cracks are due to the 2x4 frames settling in and drying out.
Does anyone know of a better way?
Thanks in advance for your time and advice.
