- Joined
- 8 Mar 2018
- Messages
- 2
- Reaction score
- 0
- Country
Hi all,
I have a question about plasterboard size for a garden office. It's built in to an angle at the end of the garden, so is a rectangle with a corner cut out. PIR (Celotex type) insulation between the studs, more on top of them for thermal bridging and vapour barrier, then 25x50 battens to create a service void and to hold the plasterboards.
The internal walls are approximately 2.1m high, with widths ranging from 1.1 to 2.8m long.
A friend who has previously done drywalling as a labourer will be helping with the finish which we will attempt with tape, compound, etc. And yes, it won't be up to pro standard, but cost is a factor. And yes, a skim wouldn't be that expensive, but still. (It's a backup option if I'm not happy with the finish.)
My question is whether it makes sense to use 3m lengths (from an online supplier) on the long walls to reduce the number of joints, vs. the increased difficulty in handling, and other factors I've read about like settlement, pressures, etc.
Likewise for the ceilings, assuming we can get enough hands to hold up the heavy board?
Boards will be supported on all edges, 400mm centres, etc.
Thanks in advance,
David
Thanks in advance,
David
