plasterboard thickness
16 Aug 2008
Im doing up my bathroom and have hacked off the old plaster & pva'd on two brick walls, the other two are internal and will be plasterboarded along with the ceiling which I will plasterboard over the existing lathe & plaster.
My question is what thickness of plasterboard should I use? Wickes has 9.5mm and 12mm in 1200x2400 sheets that I was planing to buy, but is one thickness better for what im doing than the other?
go with the 12.5 they are stronger and dont bend as much, if your dabbing they near enough stay flat and if your over boarding they make the ceiling a lot flatter, if flatter is a word, it must be the misses always says dont flatter me :D
