Hi all,
I tried searching and got lots of different results...
I have a few things I'd like to afix to walls, all internal plasterboard walls.
1) A slim fish tank, similar in size to a thick plasma, mirrored edge. Not sure of weight. This is going onto a wall, where there used to be a door, covered up now due to extension. The studs aren't in the place for the fixings.
Will Rigifx be the ideal solution, bearing in mind there is no brick/masonry behind?
http://markgrantcables.co.uk/shop/i...ducts_id=126&zenid=569u7ien94p330jiel44rnkfs1
http://deltaleigh.co.uk/products/rigifix/
2) simple toilet roll, towel holders etc... the fixings supplied are normally cheap. What should I use instead, brown rawl plugs? Straight into hollow plasterboard.
Many thanks!
Many thanks!
