I intend to fit 12mm plasterboard on a celcon block wall using adhesive, the wall has first fix electrics on it .
Just want to be sure I am going about this the right way before I start
Cables are all surface on the blocks in safe zones around 10mm max above blocks. The socket boxes are 35mm deep due to cable sizes and I intended cutting them in say 15mm into the blocks.
This assumes an adhesive finish thickness of 12-15mm. Seems that 10-25mm is the allowed thickness.
This should leave me with the socket boxes set back a few mm from the front face of the plasterboard (far enough so the side cable entries dont interfere with the back of the plasterboard).
I hope to just fill as needed and paint the plasterboard when finished.
I am assuming you place the board on the wall and thump them to get an impression from the boxes on the back then cut out for them or is there another method.
