Our 1930's house has solid brick walls and rather lumpy, bumpy plaster on the inside. As we've worked around the house decorating, we've tended to spend an awful lot of time makin gthe plaster good before lining papering the walls and painting. The end result is very good but it is jolly time consiming.
Now we're looking at decorating the lounge which, is currently wallpapered with woodchip paper that seems pretty impossible to remove.
I've been thinking about getting some thin sheets of 8ft x 4ft plasterboard and simply fixing it over the woodchip with panel adhesive then using some supa fill type filler in the joints.
This worked beautifully on one bedroom wall where the wall that was plasterboarded was between another wall and chimney breast (in a wide alcove)
However, in the lounge I'll have protruding corners to deal with - What is the best/propper way to create a nice crisp edge on corners? I've seen plasterers fit a 90 degree expanded metal piece on such an edge before skimming, but what do they do when not skimming?
