Ok the topic is not completely accurate, let me explain.
I have erected a large "shed" at the bottom of my garden, (5M x 5M) from 4 x 2 framed 12mm WBP ply. The outside coated with exterior paint then featheredged completely, I am very happy with the outside.
However I am now looking to insulate the void before plasterboarding over the top. I am using 90mm Celotext/Kingspan as the 4 x 2 used are regularised so actually come up around 92mm instead of 100mm. So you would think the 90mm insulation would slot in nicely.
Problem is that virtually every panel of ply seems to have a significant bow running down the middle of it, bowing inwards so when the Celotex goes on/in it wont run flush with the inner edge of the timbers so plasterboarding will have problems.
Does anyone have any idea of how to overcome this, short of sanding the ply or cuting some kind of recess into the insulation ?
Thanks chaps
Thanks chaps
