I'm after some advice, I have a job that I need to fix plasterboard over PIR insulation boards.....can i stick plasterboard directly onto the surface of the PIR insulation (celotex) board?
I then have another instance that the board needs to stand off insulation 10 / 20mm but on a taper as the timbers around the window are not square....can I again use some foam fix of something to fix the boards directly to the insulation without battoning and screwing?
Cheers,
Ant
Cheers,
Ant
