plasterboarding over plaster and lathe - help ?!?!?!?
5 Nov 2008
London
i have a room size of 3200mm x 4000mm.
i've had a leak and the plaster and lathe is now coming loose.
the leak is now repaired but the ceiling needs repairing.
now i'm a general handyman and trying to workout the quickest and cleanest way to fix this, as it is in my bedroom, which has plaster coving.
so i am thinking of battening up, and double layer plasterboarding with 9.5mm fireproof plasterboard.
battens every 600mm, using 60mm x 20mm battens
and then plasterboarding using 2400mm x 1200mm
so in total about 12 boards cut to 2000mm x 1066mm (roughly)
and then only wanting to skrim the joints, and then paint.
couple of questions, is this a good general idea?
any suggestions to make this easier or better?
would i use jointing tape that you soad in water first, or that plastering stickey mesh stuff over the joints, or just stick something in the joints (advice please).
then paint it white.
i know that i will be lowering my ceiling about 40mm but it is that or make a tonne of mess and more money....
oh im starting this tomorrow.... and next week.
i guess you have already started this but showing us a few pics of your ceiling would give us a clearer picture of how to help im not sure why you want to use battens and lowering the ceiling by 40mm while you have plaster coving is not a good idea, if you want to keep the coving you could overboard and use a plaster edge bead set back about 4 inches or so and then skim, also how badly damaged is the ceiling? lath and plast ceilings can be repaired which would be the quickest and easiest way to fix it "if viable"
