Usually when I build timber walls or dry line a wall with timber as I have being doing today I would always construct the timber so that every single edge of the plasterboard sits on a batten.
However, today I've dry lined a wall ready for 1800x900 plasterboard after I removed a chimney stack. I have battens along the top and bottom of the wall and then I have vertical battens every 450mm.
I'm thinking of not bothering putting in horizontal studs so that means where 2 boards meet they won't be sitting on a batten. Does this matter at all? I'm assuming after tape and skim coat the joints should be fine.
