Yet another possibly dumb question from me...
I'm (working up to) replacing a plaster & lath stud wall between bedroom and stairwell with plasterboard on one side where the plaster was blown. I decided, for better or worse, to take the plaster and laths off so I could put some insulation in and not lose any space, since the doorframe is already pretty close to the wall.
The room is about 245cm floor-to-ceiling. The thing is that the distance between the studs is 41cm except for one which is 42cm. What's the best way to board this? Do I have to go horizontally?
Also, is there any recommendation on what gap to leave at the bottom - if I can go vertically I will have 5cm with one board? In other rooms I've had to knock off the plaster at the base of the wall about this much to get the floorboard up, which go under the plaster.
