Hi all,
Hope someone can advise.
I have recently had my living room skimmed, but while the plasterer was 'troweling down'? one half of the wall he noticed a small amount of movement on the entire right side of the wall.
He figured that the plasterboard had not been fixed to anything previously and was probably just stuck to the breezeblock which had now come away.
I drilled and plugged the wall that evening to some effect (some screws pulled straight out of the walls, others seemes to hold).
The next day he re-skimmed over the previous skim and he said that he applied the same force as the other walls and there was no movement, so all seemed good.
Today, where it is starting to dry out, you can notice some damp spots where it had been drilled, but also one spot which has dried has a very fine crack around the where the screw head would be.
If I push the wall (slightly firmly), there is still around one or two mm movement (estimate), in a couple of places.
Should I be concerned about this, should I try and secure a bit better before I seal the wall, will the crack around the screw head forever be making an appearance no matter how much it is painted over...???
BTW, I have every confidence that the plasterer has done everything correctly from his end.
Pictures below, thanks...Happy New Year.
