Plastering cellar walls
7 Jul 2007
Sheffield
I need to plaster a cellar. Am I best to cover the walls with some sort of damp proof membrane first to protect from any future risk of damp or would it be ok to simply dot + dab then skim.
The cellar does not appear to have a probelm with damp at present but am I better off safe than sorry with this one?
Any advice appreciated :)
Newton System 500. Waterproofing and damp-proofing
www.newton-membranes.co.uk
It's better not to dot and dab straight onto a cellar wall, even though there is no damp problem at the moment,but you can never tell.
Newton System 500.
Probably the ultimate way in damp or waterproofing a structure. Worth a look. These can be plastered over too.
Other similar products available too, from various websites, but check the prices.
Roughcaster.
All the so-called waterproofing systems cost a bomb. If you've got no damp simply fix timber studs to the wall and plasterboard. If it wasn't damp before - it won't be damp after. Just keep it ventilated.
or you could try,synthapruff 3 coats,blind the last coat with sand then render it.
I totally agree with you Joe90 on your comments. This was more of a piece of info for the OP to show the type of membrane product/s available.
Roughcaster.
