Follow the link
peaps has posted & have a read. If your intent on boarding rather than rendering, you cant use any form of gypsum based board even Fireline, they are only designed to withstand a one off exposure & are not suitable where the temperature regularly exceeds 49 degrees. You can use a calcium silicate board such as Supalux but you cant just rely on adhesive, it must also be mechanically fixed. Personally I’d stick with Vitcas heat proof render;
http://shop.vitcas.com/vitcas-fireplace-render-260-p.asp or, as I do, mix your own heat resistant sand/cement/lime render & apply in two coats (5:1:1 - 6:1:1) & then use Vitcas heatproof plaster over that;
http://shop.vitcas.com/vitcas-heat-resistant-plaster-16-p.asp
It’s all there in the links.
